Cat. 1 Pin Distance?
Seedsntrees
11-30-2004 17:18:09
What is the distance between the pins on a Cat. 1 implement such as a mower, disk etc? Trying to establish a 3-PT for an Allis.
Thanks!
Joe(TX)
12-01-2004 18:54:59
 Re: Cat. 1 Pin Distance? in reply to Seedsntrees, 11-30-2004 17:18:09
The official dimension is 26.81 min to 28.91 max shoulder to shoulder.
willie j
12-01-2004 06:07:36
Seedsntrees
In process of making one for WD. Too long to post here. Shoot me an E-mail if this is what you are doing.
I'm on aol.
UGUSU
JMS/MN
11-30-2004 21:07:44
All 3ph specs can be found on the website of the American Society of Agricultural Engineers- www.asae.org.
RJ-AZ
11-30-2004 20:14:08
You have to dig in a little deeper there and you can get all the specs needed as to arm lenght and all the rest of the setup. The 26" distance between arm is just the start as you need to figure in the top link setup as well for proper geometry or you have a real mess.
Hay DR
12-03-2004 15:10:32
 Re: Cat. 1 Pin Distance? in reply to RJ-AZ, 11-30-2004 20:14:08
Maximum
Drawbar
Horsepower Top
Link Pin
Diameter Draw Pin
Diameter Lift Arm
Spacing Cat. 0- up to 20 5/8" 5/8" 20" Cat 1- up to 45 3/4" 7/8" 26" Cat 2- 40 to 100 1" 1 1/8" 32" Cat 3- 80 to 225 1-1/4" 1-7/16" 38" Cat 4- 180 to 400 1 3/4" 2" 46 "
wolfmantractor
11-30-2004 17:52:52
26 in.
Seedsntrees
11-30-2004 17:26:32
RJ-AZ, I'm not referring to the pin diameter, but the distance between the pins on the implement. I THINK the "standard" is about 22", but I'm not sure.
Thanks
Sid
11-30-2004 18:34:02
 Re: Cat. 1 Pin Distance? in reply to Seedsntrees, 11-30-2004 17:26:32
If you go to the site RJ-AZ suggested you will find the spread needed for the arms, as well as how far past the end of the PTO shaft the end of the arms need to be.
paul
11-30-2004 17:44:12
That doesn't sound right. I have numbers floating in my head, I don't want to mislead you but 22 is not floating in here..... I'm thinking 26 inches.....
--->Paul
Seedsntrees
11-30-2004 17:58:34
 Re: Cat. 1 Pin Distance? in reply to paul, 11-30-2004 17:44:12
Thanks Paul. I think 22" is a little short also.
RJ-AZ
11-30-2004 17:20:53
Check to the left under research and info and select "3-point specs".
