Lister plowing
draire
11-29-2004 06:54:16
I have a JD 530 with a single front wheel that came from mid Michigan Vegetable country. Am courious on how it would have been used.
I understand that the single front wheel was the front end of choice for Lister plowing, planting, cultivating.
However, the draw bar is elongated, so it must have been doing some pretty heavy pulling.. and I can't imagine this happening unless plowing.
What can you tell me about Lister farming?
John A
11-29-2004 20:50:51
 Re: Lister plowing in reply to draire, 11-29-2004 06:54:16
draire, This is a question in terminaligy. Here in Central Texas. To plow your field, so to speak useing only the bedders that came with your tractor is called "Bedding". this was mainly in 2 and 4 row equipment. To break out the previously made beds is called "Rebeding". That is what is done prior to planting with a "Lister Planter" You break out the bed a 3rd time in the planting process. " Seeds are planted in the bottom of the row, not on the top of the bed.
In the Panhandle of Texas and OK, making rows, usually 6 or 8 matched tops, in one operation is called "Listing" Hope this helps.
Later,
John A
