vermeer pto tilling machine
ray Hud
11-27-2004 15:13:14
has anybody ever used a vermeer pt12 tilling machine ? how did it work? was it easy to keep on grade? thanks
JD-Tractor
11-27-2004 20:12:24
 Re: vermeer pto tilling machine in reply to ray Hud, 11-27-2004 15:13:14
Worked for Vermeer and sold several .works pretty good best if used with a winch as they were easiest to control that way ,definately want to at least use a hydrostatic tractor, ! where are you located ? I am in western NY
ray hud
11-28-2004 05:00:08
 Re: vermeer pto tilling machine in reply to JD-Tractor, 11-27-2004 20:12:24
west ind we have tough yellow clay didnt they make 2 pto modles i would need to go 3ft deep would a pt 12 do it how do you maintain grade
paul
11-28-2004 19:41:38
 Re: vermeer pto tilling machine in reply to ray hud, 11-28-2004 05:00:08
We have yellow clay as well, neigbor has a Vermeer, I do not know the #. It works fine, slow but fine. Tile plows work a lot faster these days. he uses it with an IHC hydro tractor, think that would be the way to go, winch seemed a lot of extra fuss.
You set up a string on some stands, follow the string for the grade. Levers contol the depth, keep the finger touching the string....
--->Paul
