I'm guessing that is an Oliver combine, or relative in the Agco line? Here are the things 'wrong' with that combine: Too small. Can't work 1000 acres with it, no one wants it. Gas engine. They use 2 times as much fuel per acre. If you were running 1000 acres, would you rather buy 1050 gallons of diesel or 2100 gallons of gasoline _every_ year you owned it???? It's a good combine & operator that can cover an acre on a gallon of diesel, a gas engine brings it to around 2 gallons an acre. Parts. And reliability. If you are running 1000 acres, you need to keep the combine running. No down-time. That 'old' machine is going to need a couple bearings a year, chains, etc. If a bigger part wears or breaks, it will at least need to be shipped (wait a day or 2), if not found in a salvage yard somewhere - too much down time if you need the crop out now. Cost of upkeep. This is the one that will hurt _you_ on the small acres. Go to a dealer on a slow day here in winter & ask them what the chains, paddles, raddle, and big belts cost. You will _easily_ spend $1000 a year buying parts for the machine, even on 140 acres. Maybe less one year, but then you need a tire or hydro pump or rasp bars & concave or a $500 clean grain chain.... The parts are going to be far more than the cost of buying it. And, you _must_ be able to do your own repairs. You cannot afford to pay labor on top of the parts cost. Combines do not last sitting outside. You need them under a roof. They take up a lot of room, so they get to be a hassle to hang on to. So, here is the deal. You want to find: A combine in good condition. A combine that was real popular in your area 20-30 years ago, so there are many many around in salvage yards and groves for you to get parts from. A combine a little bigger than you need, so while it works you can haul grain, to make up for the bit longer down-time you will have with the older iron. A combine that is a little easier for us backyard mechanics to work on. You will notice that Gleaner comes up a lot..... They are easy to work on, the 2 & 4 row models were very popular in many areas a generation ago, and Agco still carries most parts you will need. I'll guess there is nothing wrong with the machine you are looking at, if it has what you want & you can find parts for it & it generally meets the above list. I'd consider offering less on that, esp at this time of year. He might be fishing, and need the shed room. It would sound at least double what a 13' gas combine of any older make would bring 'here'. --->Paul
