Need help with ID Flail Mower
Jim in Oregon
11-25-2004 07:59:53
The only info I have is on the gear box, AW87-01B(or 8). It is 8' wide, has pto shaft and 3 point hitch, it's yellow in color and has weights welded on the right side. I would appreciate any help I can get.
Thanks,
Jim
Indydirtfarmer
11-25-2004 08:46:36
 Re: Need help with ID Flail Mower in reply to Jim in Oregon, 11-25-2004 07:59:53
I'm looking through a couple impliment listings I have. There were 2 different companies that have SOME model #'s with AW in them. Alloway-RAU flail choppers, and Artsway (also marketed under the names Balzer, Dakon, Sunmaster, and Sukup)
If you could find a part # on a "wear part" (knives) I might be able to narrow it down further. John
Jim in Oregon
11-27-2004 09:05:37
 Re: Need help with ID Flail Mower in reply to Indydirtfarmer, 11-25-2004 08:46:36
Thanks to John for the info. On the gear shaft the I found the numbers :WA675DC4. Still looking for more info.
Thanks,
Jim
Allan/CA
11-27-2004 09:57:54
 Re: Need help with ID Flail Mower in reply to Jim in Oregon, 11-27-2004 09:05:37
There are several manufactors of flails on the west coast that sell locally. They in most cases buy gear boxes and fabricate the rest. It's hard to tell them apart without a picture. Some of the brand names are Verismo,Dandel( which was bought out by Rhino>), also major brands Mott(Alamo), Mathews, JD, and a couple of other companys out of Sacramento. Some of these are reverse cut and use scoop blades, the Dandel had a plate with a shock absorber to cushion the vibration to the roter. The local units were built heavy with widths to 30' to shred crops or brush. Sorry to get so long. Allan
Jim in Oregon
11-27-2004 12:57:22
 Re: Need help with ID Flail Mower in reply to Allan/CA, 11-27-2004 09:57:54
Thanks to Allan/CA. I'll look for the web sites.
Jim
