The Deere 7000 series planter is sorta like the small block Chevy engine. It's been around a while, and there are TONS of good aftermarket parts available for it. ANY planter can be converted to a no-till unit. We started no-tilling before the Max-Emerge planters came on the market. Dad "converted" a 694 Deere planter for our first 3 seasons of no-tilling. When the 7000 first came on the scene, they were a natural for no-till work. Parts became easy to get (Coulters, row-cleaners, ect) We used the same 4 row planter for the next 23 years. It has been re-built and re-engineered several times. Finally, 3 seasons ago, I finally went to 8 row....YEP! Another Deere. Max-Emerge II technology. There are plenty of good 7000series planters out there, some at good prices. Then you can take your Shoup catalogue, or whatever parts house you like, and tailor it to fit your needs...WITH BOLT-ON PARTS. No need to weld, bend, grind, or cut. The 7000 has enough built-in wieght to get your planter in the ground. It has enough heft to handle the pounding that no-tilling will dish out. If you're like most of us, planting time is all RUSH-RUSH. No time to stop every few minutes and get the welder out. Find a 7000 series and THEN start your modifying. JMHO John
