I have a 5580 with the 3 springs. Has 8 ea 5" belts. Do not have the crowder wheels. Primarily bale sudan while it's young and tender. Never tried to unroll a bale. My gut feel is that if you want to unroll one, you want it loosely packed so you only want to use 2 springs per side and your pressure settings on the lightest notch. Additionally I would suggest the pickup wide open and run as big a windrow as you can get in with the baler going forward as fast as it can bale. All that should minimize the pressure on the belts, maximize the amount of hay while minimizing the time for it to "pack" which should result in a very sloppy bale that can be unrolled easily. I think you want to stay centered on the row and not go back and forth.....just have a very fat row. Reason is that this should give you a single layer of hay in the chamber rather than Hay that came in to form the left side and a ways down the field more hay came in to fill the right side. I realize your bale will have a barrel shape but I think this is what it will take to do what you want to do. Also, I'd move the outside ties in like 6 to 8" from the sides so they won't slide off. Long stemmy crop will help too. HTH. Mark
