Hydraulic cylinder rebuild cost?
barryinmn
11-20-2004 20:13:27
What is the typical shop cost to rebuild a 1 way cylinder 24" long with 1.25" bore? It looks to have non standard ends so a simple off the shelf replacement would not be the first option.
wolfmantractor
11-21-2004 18:56:31
 Re: Hydraulic cylinder rebuild cost? in reply to barryinmn, 11-20-2004 20:13:27
Just last week paid $118.38 to ***** Hydraulics in s.w.PA to repack or whatever a very leaky 2-way cylinder on my 2250 IH loader. That was without tax.
barryinmn
11-21-2004 18:04:15
I jacked up the second bucket today to see if the cylinders were stuck. It's a two stage one way cylinder! That accounts for the double rings of bolts. The botton has a welded spacer to the housing. Rod end has a T style fitting. There is a lot of rust from years of non use.
Thanks for all the tips I'll start checking sources.
Duane WEGMAN
11-21-2004 14:30:45
about a week ago I put out a posting about a pull type road grader and you responded that you have a adams road patrol #3 I am interested in it my phone is 320-743-2353 my e-mail addres is [email protected] I do not know how to get in contact with you or where you live.
Midwest redneck
11-21-2004 14:05:52
Usually about half of list price of new is what the rebuild costs. But you may want to really look at a new cylinder in the grainger or Norhern tool catalog.
kyhayman
11-21-2004 07:49:53
My experience is that somewhere betwen $75 and $100 does a simple cylinder rebuild including the seal kit at the local fluid power shop. More on the $250-$400 range it they have to replace the rod/piston/etc.
Davidj
11-21-2004 07:06:07
I did the 2 cylinders on my loader for about 40 bucks this spring. They"re 1 1/2" bore single acting cylinders too. Good luck
Gerald J.
11-21-2004 06:06:07
I've paid as low as $25 for simply replacing O-rings, and been quoted a price twice the price of a new cylinder for grinding the piston rod down to the bottom of the pits, replating and then grinding back to size. I was charged $25 for the quote (they took the old cylinder apart) that was about $450.
A 1.25" bore cylinder is uncommon. But O-rings come in a wide variety of sizes.
Baum Hydraulics at Omaha has a wide variety of cylinder parts and seals Link
They>Link have a line of assemble your own cylinders with assorted end fittings to be welded on in the field.
Gerald J.
