Need Rock Picker Recommendation
cjf/MICH
11-14-2004 11:43:11
Am shopping for a rock picker - need to get more ground into alfalfa. Haven't been around any, just looked some over at auctions & online. The Haybuster with reel looks a little complicated, the Degleman or Schulte with revolving batts maybe a little simpler design? Are some of these hydraulically driven? Might be a problem for my older tractors? Any experience you'd care to share would be appreciated.
Chuck MI
11-15-2004 17:31:46
 Re: Need Rock Picker Recommendation in reply to cjf/MICH, 11-14-2004 11:43:11
My cousin has one, don't remember the brand but has some yellow paint left on it. If I remember, it runs revolving forks off the PTO, and the hydrolic raises and lowers the forks, and opens the back to dump.
Spends 99.999% of its life taking up space in the barn. I personally have only used a stone boat... and a strong back!
R. John Johnson
11-15-2004 10:27:17
Have you considered another option? In my area there are a lot of small rocks, fist to head size. People have local welding shops build large rollers, up to 6 feet in diameter and 10 feet wide. They can be filled with water. After picking the really big rocks they simply go over the fields with the packer. Any rock sticking up is pushed flush with the ground. No rocks to interfere with haying equipment.
John
Chuck MI
11-15-2004 17:26:24
 ??? in reply to R. John Johnson, 11-15-2004 10:27:17
Won't this lead to just a wee bit of compaction???
James in NC
11-15-2004 04:51:52
I like the schulte the best. I don't think that the old tractor hyd. would be a problem, since they don't have to turn real fast. I definitely like the Schulte better than the Vermeer and the Haybuster.
big al
11-15-2004 03:20:22
I think the teenagers of this country need to be out doing this might teach them some character.
barryinmn
11-14-2004 16:41:22
I just bought one Too old to have a brand on it. A comb tips up into a bucket which then dumps out the back. Seen them for $1500.
If you have dual acting cylinders a small tractor hyd supply will work ok as the oil goes to the opposite side of cylinder.
A single acting single hose large cyl could take the whole resevoir & partial lift could result.
