Kabota with Bush Hog rotary mower
Paul F B
11-13-2004 07:49:58
I have a L3130 w/ BH90 backhoe and a 72" Bush Hog rotary mower. I'm having difficulty with the lower links levers on the 3 pt hitch banging into the subframe for the backhoe when I raise the mower. Is there an adjustment I can make to avoid this? The levers have been dented , but still work.
tractor dan
11-14-2004 11:52:05
 Re: Kabota with Bush Hog rotary mower in reply to Paul F B, 11-13-2004 07:49:58
what if yoy move your lower lift pins to in side the frame that way your lift arms are narrower and might mis the sub frame
tractor dan
11-14-2004 11:51:59
Jerry/MT
11-13-2004 18:46:52
You might consider removing the backhoe. I have a hard time imagining a mower hooked up to a backhoe equipped tractor. How is the backhoe mounted?
Paul F B
11-14-2004 10:14:30
 Re: Kabota with Bush Hog rotary mower in reply to Jerry/MT, 11-13-2004 18:46:52
The backhoe is not on the tractor, the frame that holds it on is and stays on the tractor. Paul
ken macfarlane
11-15-2004 11:24:13
 Re: Kabota with Bush Hog rotary mower in reply to Paul F B, 11-14-2004 10:14:30
What the other fellow said rephrased is on the bushhog, move the pins from pointing out to pointing in.
Then when you hook up you will just set the 3 point arms narrow then swing them out to engage the pins.
Ken
Paul F B
11-16-2004 06:31:06
 Re: Kabota with Bush Hog rotary mower in reply to ken macfarlane, 11-15-2004 11:24:13
Thanks guys, will try the suggestions and let you know. Paul F B
