which is best to mow with a brush hug, sickel bar
Ryan L.
11-11-2004 10:32:51
hi, i am needing to mow about 40 arces of land and will have a tractor with about 35 hp to the pto. i am trying to find out which would be the best , cheapest, and fast way to cut the grass. it will be around 4 ft every time i cut it. please leave your opinion. thank you
Roy in UK
11-12-2004 23:48:46
 Re: which is best to mow with a brush hug, sickel in reply to Ryan L., 11-11-2004 10:32:51
It would be nice if you could try out a 5" disc or drum mower and try it on your tractor. I have seen one on a MF135 and it handled ok.(38 pto hp)A disc or drum mower takes more hp than a sickle I grant you, but a lot less than a bushhog in 4" high grass. It would cut through the grass like a hot knife through butter and not chew it up at all if you wanted it for hay.
pbutler
11-12-2004 13:57:45
I have both. I have cut very tall thick grass with a sickle-not fun. Also not a lot of fun going into it with a bushhog with only a 35hp tractor.
Is there any way you can cut it more often-before it gets so tall?
I use a 50hp Massey 255 with a Deere 709 mower and it is a pretty good load in 4ft tall grass-and that is a really heavy mower. Don't try 4ft stuff with a cheaper King Kutter type-at least not 40 acres worth.
Advantages both ways but with 35hp I would lean towards the sickle. Just don't try to cut when it is too wet.
paul
11-11-2004 16:27:07
I can't comprehend mowing 40 acres of 4' high grass and _not_ baling it for hay. My old conservative German roots..... . ;)
The sickle of course if it is for hay. But a sickle is much, much more fuzzy, & will require more effort from you, and will have trouble with wet grass, fine grass, gopher hills, and so forth.
The bush hog will go through all sorts of junk, thickets, etc. It will be less work but about the same time & more fuel if you want the grass ground up & not used.
--->Paul
Chuck in Ks.
11-11-2004 12:42:32
Ryan, At 4' high cut it with a cycle bar mower if you want the hay.
If you just want to cut it and leave it lay (like a lawn) than use a bush hog. There have been posts from people who remove the left side and rear of the bush hog to cut grass for haying.
Chuck
txblu
11-11-2004 12:41:13
Will agree that the sickle is best as the forage gets taller.
BUTTTTT TT The sickle is a pain in the butox. It hangs easily, gets gobbed up with fireants and grass wads, especially with wet grass, won't cut wire grass and other wirey grasses and requires constant maintenance of the cutters. Sticks out to the side so you have to watch side obstacles that are hard to remember and judge distance. It doesn't cut very fast if you don't want it skipping over the thinner stemmed/leafed forage.
Bush hog just goes RRRRR IIIPPPPP. If the grass is really tall, raise it and come back with it on the ground. 2 laps, but together they are as fast as you can go with a sickle.
Mark
sawtooth
11-11-2004 11:05:33
With 35 hp I vote for the sickle bar mower, takes a lot less hp. But it depends if you want to grind up the residue.
