Ford Tractor
Matthew4u
11-08-2004 09:23:04
Does anybody know if you can hook Hydraulics lines to a ford tractor 600. trying to hook up a front snow plow.. ????
paul
11-08-2004 11:40:30
 Re: Ford Tractor in reply to Matthew4u, 11-08-2004 09:23:04
There is a small square plate about under the tractor seat. On top of this is bolted a single or twin set of valves, possibly single acting, usually double acting. The lever(s) would typically stick out from under the bottom of the seat a bit. A single, double, or twin pair of hoses typiclly runs to the back of the tractor for quick-coupling the hyd cylinder(s).
There are several different styles of these plates & valves. They all pretty much interchange on all the 100 series Fords.
If you just have a flat plate, all of the above can be added to your tractor. You can find new, reconditioned, or used off a junker units.
Don't be confused by the little Position / Draft lever off to the right side under the tractor seat. This is for setting the 3pt mode of action, and will not run hydraulics.
--->Paul
old
11-08-2004 09:43:57
Yes you can but you need an adaptor plate to do so.
txblu
11-08-2004 11:35:27
 Re: Ford Tractor in reply to old, 11-08-2004 09:43:57
See your NH dealer with $75 in your pocket
paul
11-08-2004 11:46:32
 Re: Ford Tractor in reply to txblu, 11-08-2004 11:35:27
That would get you the thin plate, right? Then you still need the valve(s), fittings, gaskets & O rings, and hose.
Seems like it always ends up $5-600 for the whole outfit?
Or is NH having a deal these days & I need to get there quick???? :)
--->Paul
txblu
11-11-2004 07:07:57
 Re: Ford Tractor in reply to paul, 11-08-2004 11:46:32
That's the plate. The rest comes from TSC. You need an open center valve, and 2 rt angle fittings and 2 ea 24" hyd hoses, a bracket to mount to a bolt on the bell housing and 2 QD's.
Cross single (2 way) valve....$100 ish
rt angles 6
Hoses 35
QD's 36
Bracket 10
Looks like a $200 bill will do it. I think my bill was $185 or thereabouts. If you want double remotes, double the price of everything. (Double remotes means there are places for 4 hoses to attach and 2 control valves.....like you have a batwing mower and let each side down/raise separately.)
Mark
