Soldanizing stored Machinery
Michael Soldan
11-08-2004 06:45:27
There has been discussion recently about cleaning equipment for storeage and I though this might give some people a guide. I don't pretend to know everything but this works well for me everytime so I thought I would share it. I make up the following mixture: 1 Gallon of Varsol 1 Gallon of diesel fuel 1 Quart of New Motor oil Place in garden weed sprayer and slosh around thoroughly, apply to metal surfaces of machinery Avoid tires, rubber belts and components Wipe off overspray on rubber components
I apply this to pressure washed and dry manure spreader, baler, disc,hay elevator etc...any machine that I want to keep rust off. I also spray underneath my pick up truck,inner fenders, door jams, inside tail gate, wherever I can get the wand inserted. I let it drip off and the job is done. Do not use used motor oil to coat machinery, it is often acidic, contains moisture and can actually corrode rather than protect. I usually have to mix up 3 or 4 batches but it works great. I also did my son's Jeep C-7 under carriage, fender wells etc. and put it upstairs in the barn for the winter. There will be no rust appearing when this concoction is applied. I have also heard of adding glycerin to the mixture but I have never tried it as I am happy with the results I get. This is just one of the things I do when I "Winter-Up" the equipment....Mike in Exeter Ontario
Stan - Florida
11-10-2004 04:17:17
 Re: Soldanizing stored Machinery in reply to Michael Soldan, 11-08-2004 06:45:27
Mike,
Did you ever see my reply to your post on the Memorabilia board about the pedal tractor?
Stan
Punchie
11-10-2004 03:53:53
THanks!! Michael
I can look it up but yes what is Varsol??
Thanks!!
Teddy
Michael Soldan
11-10-2004 16:28:13
 Re: Soldanizing stored Machinery in reply to Punchie, 11-10-2004 03:53:53
Hi guys, Varsol is a mineral spirit, often used as a paint thinner, clean up brushes kind of product, it is petroleum based and in the concoction I make up it thins the oil and removes a lot of the diesel smell. Most hardware stores carry it, used often as the liquid in parts washers, its clear and fairly odourless, about $5 a gallon..Mike in Exeter Ontario
Irv
11-09-2004 23:36:29
I agree - in Michigan, anything not protected is going to rust very quickly. But what is varsol? New to me. Irv.
wh
11-08-2004 12:27:10
usually just wash it off and oil/grease the moldboard, disc blades. all equipment is stored inside for winter. wash and grease all places on the batwing mower when i put it up. only the disks, chisel, turning plow, drag sets out in summer. batwing mower, cycle mower, planters, cyclone spreader NEVER sets out - even overnight. when done with planters will wash and grease them. also, will spray inside of fertilizer hoppers with sometype of spray lube.
Dave H (MI)
11-08-2004 11:02:26
Ever wonder what you are drinking when you pull a glass of water out of your well? Where does that stuff go when it drips off? Seriously, I think there must be a better way. That stuff must stink up your sheds something awful! Phew!
Michael Soldan
11-09-2004 14:31:49
 Re: Soldanizing stored Machinery in reply to Dave H (MI), 11-08-2004 11:02:26
Dave, you raised a good point. I am very careful to not slosh this on, I set the nozzle to almost a mist. I don't know why but there is very little smell to this and it gives the machinery a lustre, as I said it works well for me and the end result is no rust. Storing machinery outside in Kansas or Alberta is not the same as in southern Ontario..or Michigan...Mike in Exeter Ontario
Allan in NE
11-08-2004 06:58:15
Mike,
I back any piece of machinery to the spot where it will set all winter and pull the hitchpin.
End of story. It'll be there come spring.
Allan
greenbeanman in Kansas
11-08-2004 11:55:11
 Re: Soldanizing stored Machinery in reply to Allan in NE, 11-08-2004 06:58:15
I know what you are saying Allan, but all states and countries and not created equal. In Kansas and Nebraska the climate is relatively dry, meaning little damage to an implement simply parked. Not so in other locales. I even see a difference from western Kansas where I used to be, to central Kansas where I am now.
As far as just parking, I never did even in western Kansas. I always coated undercutter blades, disk discs, and especially the platform of my combine near where it feeds into the feeder housing. That always tended to be a sticking point until it got shined up.
Allan in NE
11-08-2004 14:15:54
 Re: Soldanizing stored Machinery in reply to greenbeanman in Kansas, 11-08-2004 11:55:11
GB,
Yes Sir, as usual I didn't stop to think and you are indeed right.
Shouldn't have popped off like that I guess. :>)
Allan
Allan in NE
11-08-2004 14:12:53
GB,
Allan
Randy-IA
11-10-2004 16:46:30
 Re: Soldanizing stored Machinery in reply to Allan in NE, 11-08-2004 14:12:53
Hey , My brother-in-laws brother say's he just spray's everything with a garden sprayer full of WD40 , paint and everthing . He say's it keeps a sheen on the paint and nothing rusts . Plus I guess it's not so bad for the environment since one of it's uses is for catfish bait . He buy's it in 5 gallon bucket's . He also said though that he has to re-apply it about once a month through the winter if the tools outside . I don't know if it actually work's but he swears by it . Randy-IA
