Metal Maintenance
L
10-19-1999 18:48:31
I bought a couple of old implements--back blade, snow plow and a one bottom plow. They are rust covered. What is the best way to maintain them? Should I paint them or apply that chemical that turns rust dark? The snowplow has some pretty thin spots.
paul
10-20-1999 21:46:28
 Re: Metal Maintenance in reply to L, 10-19-1999 18:48:31
If the frame & structure are rusty, converting & painting them will be a good idea. If you mean just the working parts that contact the soil/snow, those will get shiny with use. So, just use them....
The plow might be a problem, you will cuss & swear at it until it gets shiny. Dirt will stick to the rust, instead of sliding through properly. If you have a sandy patch of ground, plow that first, it helps a bit. If all you have is black gumbo dirt, good luck....
Once the parts are shiny, you'll want to coat them. A grease, or used oil helps a lot. There are special paints also, or you can just paint it, but sometimes the paint is about as hard to scour off as the layer of rust was.
--->Paul
sammy the RED
10-19-1999 22:19:55
Do both.
