JD Model 52 Plow
Plow Owner
11-03-2004 11:42:15
I just got (inherited) a JD Model 52 plow. It is a 14" 2-bottom with steel wheels. It is still in good shape - little rust, most of the green and yellow paint, etc. The one wheel still has all of the tractions bars on it, also.
Can anyone tell me what year these were manufactured and the approximately range of value?
Thanks.
Earl S.
11-04-2004 20:06:09
 Re: JD Model 52 Plow in reply to Plow Owner, 11-03-2004 11:42:15
Green Magazine had good coverage of Deere plows 2002 Year. Earl In Illinois
schmidty
11-03-2004 16:13:15
I asked this awhile back so this may not be totally accurate. I believe they were built from "34 to "47. Look at the trip assembly. If it"s enclosed it was built after "42. Hopefully someone will correct my years if wrong. I do know that is one sweet little plow and fun to use! (The trip action impresses some people even though it"s ancient technology) Prices range from $100 to $250 depending on condition. Not sure if both wheels had lugs, mine only has them on the trip mechanism side.
Plow hard,
Schmidty
Leroy
11-04-2004 04:05:23
 Re: JD Model 52 Plow in reply to schmidty, 11-03-2004 16:13:15
The furrow wheel never had lugs because it is free rolling, the land wheel has because it has to have traction to do the lifting. I have never heard of the 52 having the enclosed clutch, only the 4B that is a heavery plow, those plows complete and with the steel on are very desirebable for use in antique plowing contests
schmidty
11-04-2004 15:43:50
 Re: JD Model 52 Plow in reply to Leroy, 11-04-2004 04:05:23
The beams on mine are numbered 612 and 613 which I"m told are Model 52 beams. The only thing exposed is the spring and lever on the trip wheel. Not trying to be contraversial, just what to make sure I know what I have. Any other way to know it"s a 4B?
Regards,
Schmidty
Leroy
11-05-2004 19:15:13
 Re: JD Model 52 Plow in reply to schmidty, 11-04-2004 15:43:50
Getting late, I ment land wheel with the clutch
Leroy
11-05-2004 19:14:05
The 52 had a 28" furrow wheel, the 4B a 32" furrow wheel, lot of information in Green Magazine a couple of years ago with beam numbers and such
schmidty
11-05-2004 19:50:57
 Re: JD Model 52 Plow in reply to Leroy, 11-05-2004 19:14:05
I looked for archives there but didn"t find any. Do you have a link? Thanks for the wheel diameter info.
Schmidty
