stocktank heater
Mike Kirkpatric
11-02-2004 18:39:02
LI am lo0oking for an old style stock tank heater that you set down in the tank and then build a fire in. They burn coal wood or cobs and were made of cast iron or heavey plate steal .I want to use it so hope to find one that is still complete. You can call me or email and i will answer. phone 7658539964 or 7659149716
RJ-AZ
11-05-2004 18:30:15
 Re: stocktank heater in reply to Mike Kirkpatrick, 11-02-2004 18:39:02
They are called snorkel heaters and the cool dudes out in Califruitis still use them to heat their redwood tank spas.
RJ-AZ
11-05-2004 18:40:42
 Re: stocktank heater in reply to RJ-AZ, 11-05-2004 18:30:15
Try www/snorkelstoves.com
led
11-03-2004 21:13:33
I don't know if this will help you find one or not but years ago, we called them "Cowboy Heaters"
Led
John A
11-03-2004 20:09:35
Mike, Basiclly what you need is a 30 or 55 gallon barrel with some rocks or scrap steel in it. Throw in 10 to 15 gal of DSL and half of an ol tire and it will keep the ice down to a minium in extreamly cold weather. This is what we use when we had more water troughs out than we had LP heaters. Good luck, It is a cheap heater for water troughs. If they get messed up you haven't lost much. Hope this helps.
Later,
John A.
rustyfarmall
11-03-2004 06:58:02
I think you can still buy those brand new, I did a quick google search and couldn't find one, but you might check at your local farm supply store.
