Measuring Plows
Plows
11-01-2004 19:54:45
I was wondering how do you measure plow size? like 14"s, 16"s, etc. Thanks for the help.
paul
11-01-2004 21:46:44
 Re: Measuring Plows in reply to Plows, 11-01-2004 19:54:45
Up on the frame, above the bottoms, there is generally a beam going back to each bottom. Measure the distance straight across the beams, include the width of one of the beams.
A very few plows could be converted between 14 & 16" for example, and could have beams offset, but works for most plows.
--->Paul
Roy in UK
11-02-2004 02:10:07
 Re: Measuring Plows in reply to paul, 11-01-2004 21:46:44
We have plows in Europe that have a feature whereby the furrow width can be adjusted on the move using the tractors hydraulics.
Don-Wi
11-04-2004 20:44:00
 Re: Measuring Plows in reply to Roy in UK, 11-02-2004 02:10:07
Don't worry, us Americans have those plows as well, although not many Kverneland's. JD, DMI, Massey, Just to name a few. Pretty sure IH and Oliver/White plows were available as vari-width plows also. I've seen 2 Kverneland plows at a dealer, they seem to be built pretty solid.
Donovan from Wisconsin
