JD model B Grain Drill
rbmporter
10-27-2004 05:00:12
I need to replace a few of the single disk openers, the dealer says they don"t stock them anymore..... ..anyone know of a cross-match disk that works?
the machine is in fairt shape, 7 x 20, 7", single disk openers, galvanized box. paid 300.00 for it. Use it to plant rye, ryegrass, pasture mix.
Brent in IA
10-27-2004 13:30:57
 Re: JD model B Grain Drill in reply to rbmporter, 10-27-2004 05:00:12
Where are you at? I am in central Iowa and have a whole drill you could take home cheap. I broke a cast gear on one end so it only works oon the left side (means 2x the passes in the field) but all the parts, openers, and everything are good. (And 1/2 of the thing works perfect, other half doesn't move).
rbmporter
10-28-2004 04:40:30
 Re: JD model B Grain Drill in reply to Brent in IA, 10-27-2004 13:30:57
thanks, Brent. I live in NJ. I"d take you up on it if you were closer. I appreciate the offer. Have a good day.
Tim(nj)
10-28-2004 17:00:54
 Re: JD model B Grain Drill in reply to rbmporter, 10-28-2004 04:40:30
Which JD dealer did you use? I get parts for my 1950 FB from ABC Groff in New Holland. You can also try
Gerald J.
10-27-2004 06:57:28
Don't stock might not mean can't get.
Try Shoup. Their fall 2003 catalog shows them. www.shoupparts.com
Gerald J.
rbmporter
10-27-2004 08:34:50
 Re: JD model B Grain Drill in reply to Gerald J., 10-27-2004 06:57:28
THANK YOU!
rbmporter
10-27-2004 08:34:29
THANK YOU!
