jd 202 plow
curt_sw_ia
10-22-2004 21:23:59
can anyone tell me anything about a JD 202 plow. one managed to jump on my trailer and follow me home a while back, and other than determining the model i haven"t been able to find out much about it. i am interested in where, when, and how many of these plows were made. the one that i have is a ground driven trip with rubber tires. i have seen a picture of one on steel. thinking it might be nice to put behind a B or maybe one of my slant dash A"s. thanks for your help
Mark Lacouague
06-22-2007 03:33:52
 Re: jd 202 plow in reply to curt_sw_ia, 10-22-2004 21:23:59
I am looking for a manual or some information on this plow. JD 202H.
Any information would be appreciated.
Please feel free to email me. [email protected]
Hayfarmer
10-23-2004 10:12:53
I don't know how many 202s were made. Came in both mechanical trip lift and hydraulic lift. When you lift the plow at the end of the row, it trips a mechanism so the hitch swings over and the other set of plows is ready to drop when you trip it again. I used one once that was a loaner, it was used and didn't plow very well but may have just needed new shares. It was hydraulic lift and seems like there was lots of mechanical linkage to make all the things happen at the end of the row that needed to happen. In my area, Washington state, guys use the 2 way plows a lot, so I think there were quite a few 202 s around, they were a forerunner to the rollover plow and were pull type instead of 3 pt. They were probably competition for the IH "tumble bug" plow. Think it also came as a 101, don't know if there was a 303 or not.
Chuck 7777
11-23-2004 18:06:16
 Re: jd 202 plow in reply to Hayfarmer, 10-23-2004 10:12:53
Curt --- Hayfarmer has given some good info on the JD 202H. It was a decent plow to use and a good design for its time.
The 202H did have a few drawbacks. One, is it has quite a few moving parts, but this really wasn"t a problem if properly maintained.
Another drawback was trash tended to build up around the standards if the plow was used in very heavy crop residue. The advantage the "tumble" or "roll over" plows had over the 202, was they did a better job of sheddind this build up of trash. This was obviously because these types of plows are turned upside down at the end of each pass in the field. The 202 design only raises and lowers at the end of each cycle.
I"m not certain how many JD 202H plows were built, but production continued until the very early 1960s. All of the 202Hs I"ve seen were on rubber tires. The 202H was a popular plow in the western states and were used primarily on irrigated land.
I didn't realize that John Deere produced the model 101. I know one was produced as a drawn two way 1 bottom plow in the 1930s and 40s, on steel.
John Deere began production of the model 303H in 1959, which was one of the largest drawn two-way 3 bottom plows built at the time. It was closely designed to the 202H, but the 303H was more heavily constructed and was intended for deep plowing. In the 1960s, I pulled a 303H using a Caterpillar D4 7U for deeper plowing and was very satisfied with this implement.
Mark Lacouague
06-22-2007 03:32:25
 Re: jd 202 plow in reply to Chuck 7777, 11-23-2004 18:06:16
