I bought a used (obviously) 1033 stack wagon about a month ago. It looks to be in good condition and I paid $6500 from a dealer in Colorado. There have been a lot of issues on getting it going. Dealer hasn't provided an owner's manual which was promised. It took them longer to deliver it (during which time my hay was rained on and just ruined), didn't provide operating instructions when it was delivered as was agreed to, didn't fix some minor thing as was agreed to. Anyway, I don't think it works right and it may be adjusted to narrow for my hay bales (40" max length). I tried to pick up some hay. First, the hay didn't go all of the way to the right and the third bale came in on top of the second. (I oiled and greased and jiggled it and it seems to work better - that one bar wasn't moving over and was preventing the bales' going all of the way over). But something else was causing the hay to stop soon enough for the third bale to overlap the second and though it doesn't seem to do that now, I don't know why that was happening. Another issue was that the "bale pick up" switch has to be pushed to "on" frequently during use - mechanic said that it was customary to have to push the "on" swich before you picked up each bale of hay. Is that right? So the repair guy leaves - I get a $100 bill and am shocked because I think this is part of the purchase deal. Anyway, I keep picking up the hay. Each time the hay goes to the second level, I get down and physically move it over to make sure it's working (which I don't think it is.) It goes up off the second table and sticks. There is a little hay sticking out on the left side and that may have hung up the stack wagon (I'm not sure that enough hay was stuck to do that, but maybe it was. The first time it stuck up, when the mechanic came out, three or four flakes of hay were sticking out - it looked like someone was being beheaded. This time not even a flake was stuck in it - just a little.) Now, at this time, I saw smoke and fluid started shooting out of somewhere. There were other problems with the way the hay went back. The bottom row was not flat, but rather was turned about three quarters. The hay was all uneven and the rods that stick up to hold the hay didn't go back enough. (the stackwagon has new brake pads. I don't know if that's the problem.) This resulted in the middle pile of hay (that would be the second time the hay was lifted off the second table) not even touching the bottom. The second pile of hay was a good 12 to 18 inches elevated off the wagon floor. The thrid stack back was seriously indented by the tine or poles that stick up (the ones that should move back as more hay is loaded). It just didn't move back properly. The mechanic that works at the equipment dealer (New Holland dealer) told me how I should adjust the stack wagon for wide bales (40"). A couple of problems I had with this are that I tend to think they should do that and I don't think that will cure the problem. I bought it over a month ago and my now-ruined hay is still in the field and I don't have an operators manual. I'm sorry this has been so long, but for it to be clear, it really had to be. Is this just a piece of junk? Or, is it a simple matter of adjusting it outward for the 40" bales? or is it operator error. I certainly am not familiar with stack wagons. I bought it more than four weeks ago and I haven't been able to pick up one load of hay. I would really appreciate any opinions or ideas about this. Thanks.
