Looking for a cutter tire rim
Jrry
10-15-2004 12:59:43
I have an 8 ft pull type cutter with the two big 15 " tires on the rear. One rim is totally distroyed. It is four bolt rim. I can't seem to find one locally. I've tried tire dealers and tractor and equipment dealers. I don't know the brand of the cutter. Any suggustions
RayP(MI)
10-16-2004 17:03:05
 Re: Looking for a cutter tire rim in reply to Jrry, 10-15-2004 12:59:43
Is it possible to replace the hub with another with 5 or 6 bolt pattern, allowing a change of wheel to a more common design? Check with a local auto salvage yard, they'll have lots of hubs and rims - usually very cheap. I got wheel spindle, and tire for a guide wheel for my plow for $25 a year or so ago.
Leland
10-15-2004 21:31:05
TRY your local welding shop ours carried blank wheels and could weld any center in you needed.
Wayne in Pa
10-15-2004 15:49:12
NH used a 15in. 4 bolt rim on 469 Haybine. You might try a NH dealer for a replacement part or a used equipment yard for a used rim.
Wayne
