494 john deere corn planter
BOZ
10-13-2004 17:36:12
Can anyone tell me what the bore and stroke is of the hydralic cylinder on the 494 planter,also what pressure cylinder should be used,also is there anywhere you can get parts for this planter.
PLEASE HELP THANK YOU!!!
Don-Wi
10-15-2004 15:41:59
 Re: 494 john deere corn planter in reply to BOZ, 10-13-2004 17:36:12
Plates can be the trickiest part, we always get them at the local coop's. If one don't have it the next one will. If the fertilizer boxes are rusted out, go to a bone yard, everything else a JD dealer can get.
Donvan from Wisconsin
Tim(nj)
10-15-2004 17:04:48
 Re: 494 john deere corn planter in reply to Don-Wi, 10-15-2004 15:41:59
Marker parts like rollers, chain, etc. are discontinued. I picked up a bunch of NOS stuff on eBay last year, just in case.
Another Bill
10-14-2004 17:23:10
We had a 494 planter and always used the standard JD cylinder that was supplied with a new JD tractor, such as a 4010 or 4020. We also pulled the planter with a Super M, and used the standard IH cylinder that came with it. Never had to change hydraulic pressures on the tractors to lift the planter. Back in the days of the 494, we used dry starter fertilizer, so we had those boxes on the planter in addition to the seed and insecticide boxes.
JMS/MN
10-13-2004 21:58:12
Like most implements, an 8 inch stroke cylinder is the standard, usually a 2 or 3 inch diameter. Pressure limit of the cylinder depends on your tractor- that is what supplies the pressure TO the cylinder. It is a JD planter, so the logical source of parts is the JD dealer. A 494 is over 30 years old, so you might have to go to salvage yards, etc. for what the dealer does not provide.
Steve450
10-15-2004 05:25:27
 Re: 494 john deere corn planter in reply to JMS/MN, 10-13-2004 21:58:12
Our 494A uses an 8" cylinder. You have to use an 8" or you're planter won't go all the way down.
