Freeman
cj315
10-13-2004 14:23:23
Hello all,
I just inherited a Freeman loader with a trip bucket. I cannot find a name tag or model number on it. Is it possible to do away with the trip mechanism and install a hydraulic cylinder to tilt the bucket?
Thanks for any info
CJ
jimont
10-13-2004 18:51:05
 Re: Freeman in reply to cj315, 10-13-2004 14:23:23
We have a Freeman manual trip loader that was purchased by my father in 1954 for our Ferguson TEA ($150.)Loader has been on three tractors since and has been on my Super Dexta since 1963. We've done every job you could imagine with that manual bucket and really wouldn't think of changing it to hydraulic (a conversion kit was available through the manufacturer).In the meantime, we've worn out two buckets ,two sets of teeth and just this year, replaced the bucket again with one from a Ford one arm loader (bolted right up).
JMS/MN
10-13-2004 15:37:03
It is easy to do if you use two cylinders instead of one. First of all, you need a hydraulic valve that will run a two-way cylinder, not just a one-way, like might be on the boom. After that, it is just a matter of determining where the pivot points are, and how long the cylinders must be. If you mount them alongside of the bucket, a short pair will do. Behind the bucket, you might need cylinders with 20-22 inch stroke or so. I rebuilt a Paulson loader many years ago, used on a reversed AC WD, and with the cylinders behind the bucket, with a quik-tach mounting system, needed 22 inch stroke cylinders to accomplish the task.
old
10-13-2004 15:17:16
Yes it is but its not easy to do and do it right. Takes a lot of figureing to make it work as it should. I did one this summer and have one in the shop setting it up now.
old
10-14-2004 14:57:41
 Re: Freeman in reply to old, 10-13-2004 15:17:16
I just posted a picture of it and the tractor its on in the tractor photos its a farmall 450 posted by Rich
cj315
10-14-2004 13:41:38
Do you have a picture of the loader you converted over the summer??? Can you email me a picture??
Bruce Hartman
03-30-2006 16:10:31
 Re: Freeman in reply to cj315, 10-14-2004 13:41:38
I also need a picture of the hydrolic dump bucket . Mine has been converted to a one cylinder dump but it will not travel far enough to dump correctley
old
10-14-2004 14:24:17
drop me an e-mail and I can I unhid my address
old
10-14-2004 14:23:40
Oliver
10-13-2004 14:49:48
It's possible to do it to the loader. Is that something your tractor can handle?
