How to set the register on NH sickle
Willie T
10-12-2004 20:13:06
How can you set the register on the NH 450 sickle mower? I checked mine and it is off,goes past the guard,book does not tell how or is there something worn that needs to be replaced. Thanks
Steve from New Holland
10-13-2004 05:10:46
 Re: How to set the register on NH sickle in reply to Willie T, 10-12-2004 20:13:06
Willie, you can not set the register on a 450 mower. Everything is preset. If everything in the pitman area is snug, then something is wrong with the knife you have in it. Also, was the cutterbar ever broken and rewelded? Steve
Farmered
10-19-2004 20:17:18
 Re: How to set the register on NH sickle in reply to Steve from New Holland, 10-13-2004 05:10:46
Is the 450 mower anything like the old Dearborn mower that was sold for the 8N tractor. I got a look at one of them today. The register is adjusted by adding or removing shims between the main frame and the inner shoe frame of the mower.If you needed any shims I guess you would have to make them out of 1/8 plate. Don't know why you would have to adjust it unless you replaced the pitman stick with one that was not the same legnth. Ed
