Baler Brake
J Kirsch
10-10-2004 18:08:01
I have a NH 275 When you pull the tongue latch pin rope it actuates the tongue latch and is supposed to activate the right wheel latch simultaneously. The tongue latch works OK but the wheel latch does not. I tried to shorten the cable from the pole over to the wheel but just can't seem to get it right. I am considering putting a turnbuckle in the line but maybe one of you has faced and solved this problem before me and can give me some advice. Thankyou. John in NY
Ernie Bob
10-11-2004 10:58:49
 Re: Baler Brake in reply to J Kirsch, 10-10-2004 18:08:01
John, We also had the same problem with our NH276 and we solved the problem the same way you're suggesting. With the turn-buckle in line with the cable you can periodically tighten it as the cable streatches.
J Kirsch
10-11-2004 13:20:44
 Re: Baler Brake in reply to Ernie Bob, 10-11-2004 10:58:49
Thanks Ernie---John in NY
