Dearborn Sickle Bar Mower Axel Bracket Needed
MTBob
10-09-2004 16:57:31
Does anyone sell a right side rear under axle bracket for the Dearborn 14-15 6' mower on an 8N? It pins the swing arm and spring in place under the tractor. (I read in other posts that it does not attach to the top link, but mine seems to fit in the top link with some struggle.) I need the other mounting bracket to finish the hookup...
Jim.UT
10-11-2004 18:43:36
 Re: Dearborn Sickle Bar Mower Axel Bracket Needed in reply to MTBob, 10-09-2004 16:57:31
I just sent you an email that may interest you.
Scott PA
10-09-2004 18:20:57
They sell on Ebay often, I would recommend the special top link bracket also so your pto is at the correct angle and length for raising and lowering. Do you have the lift arm extensions?
MTBob
10-10-2004 10:10:46
 Re: Dearborn Sickle Bar Mower Axel Bracket Needed in reply to Scott PA, 10-09-2004 18:20:57
Thanks Scott. I don't have lift arm extensions nor the special top link. Are there photos of how the mower should be hooked up? The photos posted here a few years ago are broken links. It seems the top mower arm was cut and welded in the past, but you are right it does not lift properly. The mower can just hang there, but does not lift well. Where can I see how it should be connected and where can I get these parts to connect the mower correctly? Any ideas?
G Weber
06-04-2005 05:13:03
 Re: Dearborn Sickle Bar Mower Axel Bracket Needed in reply to MTBob, 10-10-2004 10:10:46
I am interested in the same top link bracket & lift arm extension for dearborn model 14-15 sickle bar mower. Pictures of these & complete hookup with the deminsions would be helpfull.Any information would be appreciated.
Scott PA
10-10-2004 17:51:31
Check Ebay auctions for lift arm extensions and brackets and N-News for a copy of a manual by mailing stamps.
