McKee snowblower gearbox seals...leak bad!
Justin-PA
10-06-2004 10:58:04
The 6" 3pt snowblower I just bought has bad seals on the gearbox. I have everything apart right now to clean it up, etc. I opened up the gear box, the gears look good, no appreciable play in the bearings. But when I filled it with 80W90 gear oil, and tip the gearbox on its side, the oil drips right out past the seals!
Is it easy to replace these seals? How do you get them out? I"m assuming I can get replacements at TSC or a local bearing suppier? Any help would be appreciated. Thanks.
Justin
JMS/MN
10-07-2004 14:14:24
 Re: McKee snowblower gearbox seals...leak bad! in reply to Justin-PA, 10-06-2004 10:58:04
Normally, seals can be removed from the front side with a good screwdriver. Before you mess them up, look for a number, so you can get the right one or cross-reference to another. Check the shaft to see that it is not worn down- if it is a new seal does you no good, need to get the shaft built up and turned to the original size.
