Dearborn 6 ft sickle bar mower
clearfield
10-04-2004 15:12:42
Hello group Does anyone know anything , good , bad about a Ford Dearborn 6 ft sickle bar mower
and can a person still order parts for it. ???
MTBob
10-09-2004 16:49:38
 Re: Dearborn 6 ft sickle bar mower in reply to clearfield, 10-04-2004 15:12:42
Does anyone sell these RH tractor rear axle brackets online?
Scott PA
10-04-2004 17:15:40
The commonly replaced parts are still available from a New-Holland dealer, it requires a special top link bracket and a RH tractor rear axle bracket that are not usually with a mower when it is sold now days, sometime the brackets are sold on Ebay.
E. Ray
10-05-2004 05:06:38
 Re: Dearborn 6 ft sickle bar mower in reply to Scott PA, 10-04-2004 17:15:40
Scott, when you say � RH tractor rear axle bracket that are not usually with a mower when it is sold now days,� are you talking about the anti-sway bar that connects under the axle to the fender mounting bolts? I bought a 501 mower and the stabilizing bars are missing. Was wondering if I could use the anti-sway bar instead..... ..... .thanks..... ..... .E. Ray
tlak
10-05-2004 15:47:39
 Re: Dearborn 6 ft sickle bar mower in reply to E. Ray, 10-05-2004 05:06:38
Your 501 will have clamps that clamp to your lift arms, these and your three point hookup will get you going.
E. Ray
10-06-2004 04:58:54
 Re: Dearborn 6 ft sickle bar mower in reply to tlak, 10-05-2004 15:47:39
tlak.....Let me start by saying that I have never mowed with a sickle mow and know nothing about their operation. I bought this mower at auction and a fellow on the board was good enough to sent me a manual on it. That is when I realized that the clamps were missing. Was wondering if the standard anti-sway bar would serve the same purpose?..... thanks..... E.Ray
tlak
10-06-2004 06:43:45
 Re: Dearborn 6 ft sickle bar mower in reply to E. Ray, 10-06-2004 04:58:54
The clamps hold it from tilting and the left side also has your bar pickup. The sway bar will just keep the whole thing from moving side to side.
E. Ray
10-06-2004 15:30:11
 Re: Dearborn 6 ft sickle bar mower in reply to tlak, 10-06-2004 06:43:45
Yes, I have the left side bar pick-up but, do not have the clamps.
tlak
10-07-2004 02:51:09
 Re: Dearborn 6 ft sickle bar mower in reply to E. Ray, 10-06-2004 15:30:11
Did have an extra set but recently lost one side off my mower. If I find it I might sell the other set.
E. Ray
10-07-2004 03:46:37
 Re: Dearborn 6 ft sickle bar mower in reply to tlak, 10-07-2004 02:51:09
There is an other 501 that will be coming up at auction this fall that has all the pieces. Will try to buy that and sell what I have. If I can't get a complete mower by next spring and you find your, will be interested....thanks.....E. Ray
tlak
10-06-2004 05:11:07
clearfield
10-04-2004 15:14:01
Forgot to say it a # 14-59 model.
