Remove Rotary mower slug before adding gear oil?
steve_ne
09-28-2004 08:49:46
Its been forever sence the oil has been changed in my rotary mower gear box. The oil has turned to slug (I think??). Is it important to remove this Or was grease add to the gear box to prevent it from leaking the gear oil? No leaks can be seen at this time and from what I can see the seals look good. I plan on using 90wt gear oil any assistance?
txblu
09-28-2004 09:18:51
 Re: Remove Rotary mower slug before adding gear oi in reply to steve_ne, 09-28-2004 08:49:46
I like to use a battery watering squeeze hootus (bulb with nozzle about 6" long) to suck the old fluid out as best I can before putting in new. And I think that a periodic replacement of gear oil is in order.
Mark
Leland
09-28-2004 17:18:08
 Re: Remove Rotary mower slug before adding gear oi in reply to txblu, 09-28-2004 09:18:51
Most of them are like a harley no need to change oil,it changes it's self.
