equiptment winter storage (outside)
jb34567
09-28-2004 08:21:54
thinking of leaving some hay equiptment outside for winter. what should i do to keep dry?
does anyone store equiptment outside? thanks
Jim Calhoun
09-29-2004 07:49:50
 Re: equiptment winter storage (outside) in reply to jb34567, 09-28-2004 08:21:54
Remember, there is no unimportant piece of equipment. It all has a job to do and must perform well when called upon.
Find a way to put it all in the shed or cover it good. It will really pay off in the long run.
You might put the heavier equipment on blocks to help save your tires.
Leland
09-28-2004 17:22:03
Drowned in used motor oil after a complete cleaning and grease good like others said. But a cheap tarp is better than nothing. just stack bales on it to hold er down.
old
09-28-2004 14:50:28
All my hay stuff is out side all year, wish I had a shed but I don't. I don't trap them either since the tarp doesn't last till spring. But and heres the key to leaveing them out side. Grease the $#%^ out of every thing oil the chains the same way and all other moveing parts. Then in the spring before you even hook it up to a tractor. Regrease every thing and reoil every thing. I've done thins for 20 years and so far I haven't had any problems.
JOHNSEPA
09-28-2004 13:27:22
Rubber roofing works better and lasts longer then plastic tarps. You should be able to pick up pieces at auctions. I usually pressure wash, grease, oil (especialy the baler chains) and cover with rubber. The only thing I don't have room for inside as far as haymaking equipment is the haybine.
Allan in NE
09-28-2004 08:45:36
Heck,
Just park it and forget it; it'll be there next spring no worse for wear.
Allan
rustyfarmall
09-28-2004 09:05:26
 Re: equiptment winter storage (outside) in reply to Allan in NE, 09-28-2004 08:45:36
I've never known anyone to put haying equipment inside. Except for the hay baler, it does need to spend the winter under a roof. If you don't have a shed for it, get one of those cheap plastic tarps at wally world.
Dave H (MI)
09-28-2004 11:03:35
 Re: equiptment winter storage (outside) in reply to rustyfarmall, 09-28-2004 09:05:26
Oh no, no, no, no, no.....
Park the rake outside if you will, but throw a tarp on her and make sure the tires aren't in full sun.
Park your mower outside if you have to, but definitly put a tarp over it to keep the sun from eating the paint.
Your baler? Buy a REALLY good tarp and put it OVER the cheap tarp. Clean all the crud out of the chute and the notter area. I have a seperate small tarp that goes over this area. Tie it all together real good and then block the sun from your tires.
You will regret it if you do not take care of your equipment. Sun is a bigger enemy than rain and snow.
Aaron
09-28-2004 13:41:21
 Re: equiptment winter storage (outside) in reply to Dave H (MI), 09-28-2004 11:03:35
Must agree with Dave on this one. Take the time to clean it well, lube it better, and cover it with quality tarps, canvas if possible. Nothing worse than dealing with rusted parts from hay holding moisture. I have two haybines, and a round and square baler. They don't sit out overnight. Rakes are lubed well and covered for winter. I don't like faded paint either.
Dave H (MI)
09-28-2004 18:00:47
 When the time comes.... in reply to Aaron, 09-28-2004 13:41:21
I want to go to HIS auction.
Aaron
09-29-2004 10:51:32
 Re: When the time comes.... in reply to Dave H (MI), 09-28-2004 18:00:47
Dave, It may be awhile. I'm 25 years old, and hope to be doing this farming thing for a time yet. Thanks for the compliment though!
punchie
09-29-2004 15:27:44
 Re: When the time comes.... in reply to Aaron, 09-29-2004 10:51:32
I was thinking the same thing when I read his post yesterday.
LOL
ken macfarlane
09-30-2004 14:36:12
 Re: When the time comes.... in reply to punchie, 09-29-2004 15:27:44
The blower and bushhog live outside here. Luckily the balers, mower, rakes and tedders live inside.
Some neighbours leave their balers out open all year but they usually have broken equipment too.
Ken
