Indydirtfarmer
09-28-2004 03:18:40
Re: SMV symbol and speed in reply to Tim(nj), 09-27-2004 21:02:50
I live in Kentucky, and farm MOSTLY in Indiana. The 2 states have COMPLETELY different laws pertaining to trailer towing. SAme applies to hauling farm equipment on the road. Kentucky doesn't require trailer lighting, unless you're on an interstate, or pulling at night-time. If the truck lights are visible from behind the trailer, you don't need lighting at all, except on the interstates again. Indiana requires trailers to be lit properly, no matter what. If it's a licensed trailer, those lights need to be working, EVEN if it's being towed with a farm tractor. (Kentucky doesn't require license on trailers) SMV laws are vague. It isn't reccomended to use an SMV emblem on vehicles going over 25 MPH, but it isn't illegal. Now comes the "common sense" part... I mount all my SMV emblems with those "socket mounts" that are so common. That way, I can pull them off when I'm in a situation where I don't need it. If I'm going to be out on the road, going 30-40-50 + MPH, why run one. It just diminish's the importance of using one when it IS needed. The only things I use "stick on" SMV emblems on are the combine, an old baler, and a liquid fertilizer nurse tank (wagon) that wouldn't allow being towed over 20 MPH if my life depended on it. You're talking about YOUR saftey, as well as the saftey of everyone else on the road. Use SMV emblems for their intended purpose. ON VEHICLES GOING UNDER 25 MPH! BUT...That needs to be looked at with relative caution. If you're going 30MPH on a 70 MPH highway, you might want to re-think the 25 MPH limit. Like so many other things in life...JUST USE GOOD COMMON SENSE! John
