Hesston 530 trouble
Roger in NH
09-27-2004 14:53:33
Loosing the chain quite a bit and fine second and third cut hay is always gumming up the rollers and binding the machione up.
This is our first round baler and I am wondering how much of my trouble is the nut behind the wheel.
Also anyone got some advice on repairing baler chain?
thanks
HAY BUD
09-28-2004 18:37:53
 Re: Hesston 530 trouble in reply to Roger in NH, 09-27-2004 14:53:33
I HAVE A CASE INT 8420,I THINK ITS THE SAME BALER. YOU MAY BE BALING HAY THAT IS NOT DRY ENOUGH. HOW OLD IS YOUR BALER ? ARE YOUR BELTS TO SMOOTH TO START A BALE , HOW FAST ARE YOU GOING WHEN YOU START A BALE,PTO SPEED MAY BE TO SLOW. CHECK ALL OF THE SPROCKETS THAT THE CHAIN OPERATES FOR WEAR ,AND THE CHAIN FOR WEAR.
RogerNH
09-29-2004 21:23:24
 Re: Hesston 530 trouble in reply to HAY BUD, 09-28-2004 18:37:53
Hey HayBud,
My baler is about ten years old and the hay is very dry (we did put up some baleage with it last year and found it to be to troublesome)
seems to have trouble with lighter second cutting hay. I broke the main drive chain this last outing .
I'm running a Massey 175 in seocnd gear low range with 540 rpm
