drill
OKLAHOMA
09-27-2004 14:45:12
Just bought an old drill. Havn't brought it home yet. It is green with steel wheels. Looks intact, the guy said it worked fine when he parked it. No hydraulics. Question is this. Can it be pulled home without the drilling business being engaged? I don't want to wear it out on the way home. I am sure this is not enough info for someone to guess what brand it is I did not look very close. I was so excited to get it!
JMS/MN
09-27-2004 17:26:10
 Re: drill in reply to OKLAHOMA, 09-27-2004 14:45:12
All drills had a disconnect, to stop it on turns or in transport.Some don't work anymore. Pull it a few feet and see if either the drill shaft (under the seed box) or the grass seeder- if it has one- is turning. If not- ok. Generally the worn part is a cast yoke with a taper to it, that pushes/pulls on a disconnect portion of the drive. With age, the taper wears until forward motion of the yoke does move the clutch parts far enough apart to separate, and disconnect the drive. Last resort- take off the drive chains if so equipped.
