3 POINT DISK
David(Ala)
09-26-2004 20:50:56
Been looking at new 3 point disk. Some have sealed bearings and some have boxed bearings, both from same manufacturer. Which is best? Be using it a couple times a year on small acreage.
Thanks,
David(Ala)
Indydirtfarmer
09-27-2004 04:00:30
 Re: 3 POINT DISK in reply to David(Ala), 09-26-2004 20:50:56
Several factors come into play. All things being equal, the sealed ball bearings are probably better. Ball bearings will offer (somewhat) less rolling resistance. They will require some attention over their lifespan. They don't like dirt as much as "boxings". They are USUALLY more expensive initially, but roughly the same cost, should replacement be needed. Just keep them greased, and the dirt will stay out for the most part. (A lot depends on design...A GOOD disc will be sealed from dirt better than some others)
Boxed bearing have been around for ages, They are somewhat more forgiving of dirt, and poor maintenance. (They still NEED grease and service) If you're only doing a small acreage with them, it would boil down to cost, as either will do a satisfactory job. Also consider the weight of the disc. If you feel it will be neccisary to add weight to the disc, in order to get it "in the ground", roller bearings will handle the added weight better. (Once again, provided that the disc is "well designed") I have an 8' lift-type disc that I use in building new lawns. It has the boxings. I run it with about 400lbs added to the frame. It has handled the added "abuse" without a whimper, for 7 years now. John
