MF Round baler, what gives?
Jim Calhoun
09-26-2004 19:48:52
I was shocked to see someone baling hay, using a MF big round baler, pulling it with an old Ford 9N.
The bales looked to be normal sized and the tractor seemed to be moving right along....
I didn't think a tractor that small in weight and horsepower could handle a big round baler, what am I missing here?
farmer mike
09-27-2004 07:36:29
 Re: MF Round baler, what gives? in reply to Jim Calhoun, 09-26-2004 19:48:52
I used a Vermeer with an AC-WD. The dealer turned the baler gear box 90 degrees to set it up for a 1000 RPM PTO. The baler turned slowly, but I had plenty of torque to run the baler. Not the best set up, but it worked.
Hay Dr
09-27-2004 06:04:38
25 PTO HP would pull a 504C but for safety reasons it is not recommended.
James in NC
09-27-2004 05:37:42
It might have been an older Vermeer 504C that they made for massey. I know folks that pull them with 35 fergusons but never heard of and 8N. On the other hand if you rigged up some hyd. lines and turned up the power I guess it would work.
Tim(nj)
09-26-2004 20:34:18
Although a Funk flathead 6 or V8 conversion would give it the HP, I doubt an old N would have the hydraulics for a round baler. Wonder if the baler had been modified with its own engine and hydraulic system? It has been done . . . .
paul
09-26-2004 19:58:31
Could it have been an 800 eries Ford? Or an N with a v-8 or whatever they do with them?
--->Paul
Bob
09-26-2004 19:57:34
What are you missing???
FORD POWER that's what!
It wasn't a Funk conversion, was it?
Jim Calhoun
09-28-2004 08:11:31
 Re: MF Round baler, what gives? in reply to Bob, 09-26-2004 19:57:34
It was an older baler, but it did not have any modifications or an extra engine, and the tractor was definitely stock.
It seems to me that a round baler would twist the PTO shaft right off that old Ford, but it was obvious that that was what the guy uses regularly. He had 150 - 200 bales tied and was still going at it!
