General Bearing removal methods
JD Jim A.
09-26-2004 18:42:31
Can anyone go into detail on methods of removing all types of bearings? For example- say you are working on a machine that has a shaft supported by a ball bearing at each end. There is no good way to get in behind the bearing to pound it off with a hammer and punch, and no good way to get a puller on it. also keep in mind that everything is usually very rusty, and that I might not always have access to a torch. Any tricks?
Ol Chief
09-29-2004 21:08:48
 Re: General Bearing removal methods in reply to JD Jim A., 09-26-2004 18:42:31
Freeze the shaft w/dry ice only costs $0.79 per lb.
RayP(MI)
09-28-2004 06:22:22
Piccture looks a lot like the one that gave me fits on my baler this summer. Even after I got the bearing apart - race was broken, balls missing, it was frozen on the shaft. Tried gear puller, etc. Nothing moved it. Finally removed it by cutting it with a cutoff wheel on a Dremmel tool. Then I was able to break it apart with a chisel. Hacksaws, and sawsall wouldn't touch it. Dremmel tool is a vary valued tool in my box!
Kelly C
09-26-2004 21:15:18
third party image
A torch is on my to buy list. I've had my hands full of bearings and stuck bolts this year.
Here is one way though. Used my puller as a pusher. Pushed the rod through the bearing and pushed out the bearing on the other side at the same time.
kyhayman
09-26-2004 20:06:42
There is a bearing puller too that has a lip to fit behind the bearing after removing the flange. Lips clamp behind it with bolts and then pulls. This is one of these 'specialy jobs' that the only thing I know to do is 1. heat the bearing, 2 get a puller set, 3. shrink the shaft with dry ice. Might, and I stress might, get a chisel and either shatter the outer race or if you get lucky pry the whole bearing loose. Then cut the inner race with a chisel. Thats the usual way I wind up doing it with a torch. Best money to be spent on the farm, for me, was $199 for a set of torches and $300 for the tanks.
JMS/MN
09-26-2004 20:04:52
With no torch, it is more difficult, but remember that bearing races are often brittle, and can be broken with a hammer and chisel. Do you have access to a die grinder? Cut a slot or two and beat it out.
paul
09-26-2004 19:59:54
My torch is on wheels. :) works for me.
--->Paul
