John Deere 336 hay baler timing is off
Michelda
09-26-2004 14:15:08
I am posting this for my father, he is needing to know how to set the timing for the tie, grip and cut on his 336 baler. The timing is off. Any suggestions will be appreciated.
David from Kansas
09-26-2004 19:03:29
 Re: John Deere 336 hay baler timing is off in reply to Michelda, 09-26-2004 14:15:08
Michelda,
You need an operator's manual. It shows clearly how to time the baler. My two brother's replaced a broken knotter frame on a 346 a couple of months ago and I helped them time it but still used the manual. It tied perfectly when put back into use.
Good luck.
David
David from Kansas
09-26-2004 18:47:55
Michelda,
Good luck.
David
