Hey Phil Tibbetts
MF41 mower
09-23-2004 15:47:24
Is yours an MF 31 or 41? The 31 has the cast? housing at the head. Yes, your numbers are different than mine and that's why I ask. You are correct, the smaller diameter of the head pulley would make it turn faster. The difference is in the 'engine' speed, which I alluded to in my last post. Apparently Massey doesn't want you/me to overspeed the crankshaft trying to cut hay faster;-)
>"PTO speed (rpm) 540 575 610 650 685 720
no. of shims..... ..5..... .4..... 3..... 2.....1.....0
"< On my op. man. 5 shims= 455 PTO 'Recommended RPM' and 0 shims= 630 PTO 'Recommended RPM'. Yes, there are too many pto/rpm combo's. I will check for those shims and try to get a measurement.
