flail choppers
COWMANSAM
09-21-2004 05:01:02
I was wondering if any body still makes a flail silage chopper to cut grass silage?
willyz
09-26-2004 05:57:23
 Re: flail choppers in reply to COWMANSAM, 09-21-2004 05:01:02
I once used a Hesston #10 Stackhand to make grass silage.
I took the flails, which were wore considerably, and turned them around. They could be replaced by the paddle type flails such as the cutditioners used to use, this I have to research. I thought it cut the grass pretty well. The problem came when I tried to unload it. I broke the apron chain.
I should of added bars to the chain and used the slippery lining that they sell to line dump trucks to the floor and sides of the Stackhand.
The experimenting continues. If you're interested I'll keep you posted. If I can get the bugs out this will work as well as the lascerators/wagon set ups I've seen sell for $20,000 or more.
COWMANSAM
09-26-2004 06:08:07
 Re: flail choppers in reply to willyz, 09-26-2004 05:57:23
Please keep me posted on how this works out. I did not hide my email address so you can contact me directly. Is this a machine that leaves the movable stacks that look like a loaf of bread? I am in Shelbyville, Ky. Thanks , Sam
52BMAN
09-22-2004 18:40:26
I have one at work. It's called a Lacerater. It came from Texas. I could get you the guys name and number if you want. It cost $5,000 for a good used 6 ft. They can be 3 pt. or pull type.
Don-Wi
09-21-2004 20:27:47
Gruett's in Potter, WI makes some. I've seen them in their back yard, they almost look like they hook onto the 3 pt. I'm sure their is another part to the hitch that I didn't see that it hooks on like a normal chopper.
Donovan from Wisconsin
You can find them on the Agco Locator
EMZ
09-22-2004 18:05:45
 Re: flail choppers in reply to Don-Wi, 09-21-2004 20:27:47
They hook right on to the drawbar and follow straight behind the tractor. It is a simple machine in that the flails are the only moving parts (no blower) They throw the feed right up and into the wagon.
CamR
09-21-2004 18:17:21
I have a Gehl model 72B flail chopper and use it heavliy. It works really really well and is uncomplicated.
Sighombre
09-21-2004 09:42:37
New Holland makes a new model #38 crop chopper and John Deere makes a new #720(?) Flail chopper.
Sighombre
09-21-2004 09:47:12
 Re: flail choppers in reply to Sighombre, 09-21-2004 09:42:37
It is a JD #972, not 720.
paul
09-21-2004 06:49:04
With the big hood going up the middle & back? Yes. Now, who was it???? One of the better known short line companies. It's on their web site.... Saw it about a year ago.... Dern memory.....
--->Paul
Tim(nj)
09-21-2004 10:01:52
 Re: flail choppers in reply to paul, 09-21-2004 06:49:04
Hiniker, I think. Only thing left from the Fox-Brady line in their offerings.
Indydirtfarmer
09-21-2004 11:02:52
 Re: flail choppers in reply to Tim(nj), 09-21-2004 10:01:52
Timing is everything! I was about to post a question about a Fox 2 row silage chopper. I'm gonna drag dads old chopper out of the weeds this week. Wanted to know who owns the name nowdays....Thanks. John
