Snow blade on 8N
jl
10-08-1999 10:07:32
I have a snow blade that came with my 8N. It has one large cable which runs under the right side of the tractor and is attached to some sort of lever. It is not clear where this lever should attach to the three-point or if I need another piece to attach it. Any ideas?
Ray LaFreniere
10-11-1999 09:12:06
 Re: snow blade on 8N in reply to jl, 10-08-1999 10:07:32
Not sure what make your snow plow is. The Dearborn model had two cables; one for each side. The front of the cable came up through the pulley and fastened to the front axle. The cables ran back to a bar under the rear of the plow. This is attached to a curved bar held on with pins. This was placed over the side arms of the three point hitch. You can send me an email directly for more help if needed.
