E. Ray, Unfortunatley, I do not have access to a reliable FAX machine, however, if you send me your mailing address, I'll gladly copy the book and send you a copied version of it. Here's the step-by-step process I go through to mount my mower: 1. back the tractor up to within about 6 inches of where it needs to be to attach the lift arms on the tractor to the attachment points on the mower 2. attach the mower's PTO shaft to the tractor's PTO 3. back the tractor the rest of the way back so that the lift arms can be attached to the mower 4. attach the lift arms to the mower 5. attach the stabilizing arms on the mower to the lift arms on the tractor by forcing them into position and then tightening the attaching clamp bolts to hold them into place 6. lift the mower and then use a screw jack to lift the back of the mower a little bit higher so that you can attach the top link on the mower to the top link attaching point on the tractor - be sure that the big hairy spring is not yet attached to the top link 7. with the mower still raised, attach the big hairy spring to the top link using the pin and clip that go through the spring and top link 8. remove the screw jack that is holding the back end of the mower up and you're on your way All of this is predicated on the fact that the main part of the mower is resting on a cement block and that the bottom of the sickle bar is resting on a surface that is about 3 inches lower than the surface that the mower is resting on. If you don't have it sitting on a stable block that is approximately level, you'll never get the lift arms attached and the mower will have a tendency to fall over either backwards or toward the sickle bar. So, maybe you've had better luck than I did when I started mounting it, but I have had the machine tip over, fall backwards, and generally been uncooperative with trying to get attaching points lined up. Good luck, and send me your mailing address if you'd like a copy of the book. It will take a couple of days to get it copied and mailed, but I'll be glad to do it. Tom in TN
