new holland 479???
Tractor Dan
09-19-2004 07:34:24
i just picked up a nice 479 the only problem i see is a small chunk of rubber missing off of one roll also the chain that drives the bottom roll is missing and the old owner says he has run is for many years with out this chain.
my question is will it hurt to run without this chain and are these a good mower what should i look out for??
thanx dan
Hugh MacKay
09-19-2004 15:12:54
 Re: new holland 479??? in reply to Tractor Dan , 09-19-2004 07:34:24
Dan: How are you doing? I suspect that vendor that ran without the bottom chaim probably mowed some light hay. If the photos you sent me are typical of hay you are mowing you best find another chain.
Had a neighbor come one day, wanted (older gent) me to see if I could figure out why all of a sudden his NH haybine with intermeshing rolls wouldn't take hay very well. We walked the field about 250', found the chain, repaired it, and his problem was over. He was mowing a very heavy crop of hay. Unless your camra makes VT hay look like SUPERHAY, you better buy a chain.
