Vermeer 505 super I
Randy-IA
09-18-2004 15:24:15
Could anyone tell me anything good or bad about this baler ? Is it a hard core or soft ? I know it's old but does it start rolls easy ? And a few more uninformed questions , What do the rubber star wheels on the outer ends of the pickup do ? Is this the type of baler you have to do a quick reverse and stop to get the bale out of it ? It doesn't seem like the steel roller on the bottom is long enough to assist in getting the bale out or does it have a kicker ? Don't know anything about these things . Thanks . Randy-IA
James in NC
09-19-2004 13:26:29
 Re: Vermeer 505 super I in reply to Randy-IA, 09-18-2004 15:24:15
The baler was made in 90's so its not that old. It is a hard core bale and the large roller in the bottom supports the bale when baling. The Hay Saver wheels on the side are to help funnel the hay. It is an open throat baler that will start bales easy. The kicker was an option. After the bale is tied off the operator must cut the pto off and back to dump the bale if there is not a kicker. Overall a very good baler, used ones won't be around long.
Randy-IA
09-21-2004 21:37:14
 Re: Vermeer 505 super I in reply to James in NC, 09-19-2004 13:26:29
Thank you , James ! I've heard good things about all Vermeer balers . Can the bale be made to any size with this baler ? Randy -IA
