R. John, I have mentally gone thru your situation several times. I mounted a 2 gallon pump up sprayer on the tongue with bungie cords. Hope I never need it. But the thought of a fire in the first place. The panic of what am I looking at. What do I do next? What about the heat as you mentioned? How do I save the baler? The tractor? Me? Hope I never have that happen. I would not have thought to dump the bale. Great idea. Will remember that. Otherwise all I have to do is pull the pin (which is held in place with gravity) and drive off. Everything else is breakaway. (Now that I have had the opportunity to mentally go through it....thanks to you.) You figure that dry grass is just a powderkeg just waiting for an opportunity to go up.
An overheated bearing, due to no grease surely would be a source for reignition. The straw you mention is all over me too. I like to bale sudan early, makes it tender, big fat leaves, and literally no stem. But the tender leaves (like alfalfa) break up and fall off while the bale is turning and pack up in the front. Glad you'r happy with the new one. Insurance didn't hurt I'm, sure. Mark
