Spring vs Fall Alfalfa
Joe in IN
09-17-2004 06:41:14
On the same line as the 6 acre question below.....
I have about 12 acres that the beans will be off in about 2 or 3 weeks. Then the cash rent(to a local farmer) will be done and the ground is mine. I ideally want a hayfield back there but Early Oct is too late in Indiana to plant alfalfa.
Thus my current plan is to drill wheat, get that off in July, bale straw, then plant my hayfield in August. I have read that fall planted alfalfa has less weeds than spring planted and is ready to cut with the 1st cutting in the spring. Someone(RICKL) mentioned worse luck with fall planted alfalfa. So what are the thoughts out there on fall planted alfalfa? Will the stand not be as good?
Note: I really don't want to seed both as I need a good cash crop next year to help pay for the land(don't want yield of wheat to be affected)...
John in IN
09-19-2004 07:43:26
 Re: Spring vs Fall Alfalfa in reply to Joe in IN, 09-17-2004 06:41:14
Hi Joe, I have seeded into wheat in late winter to early spring with good sucess. Plan on doing it this spring. I like to use a four wheeler with a small mounted broadcast seeder. It doesn't leave as big a foot print as a tractor. Tractor will work also. I like to seed it when the ground is a little sticky. Some in my area of mid-north Indiana also will have it broadcasted in with the spring fertilizer. Maximize one trip using a Terra-gator. I have seen great stands using this method. You can get three crops this way. Sell the wheat, Bale and sale the straw, and if you get rain, a cutting of hay in Sept. This cutting will have some wheat stuble in it. Next spring you are on your way to having a nice stand. Good Luck, John
tim[in]
09-18-2004 07:12:38
i would plant the wheat then in january or february broadcast the alfalfa. frost seeding always worked good for me. ive dont the august seeding once was ok. spring and oats worked good too.
paul
09-18-2004 10:44:37
 Re: Spring vs Fall Alfalfa in reply to tim[in], 09-18-2004 07:12:38
Do you run the snow blower up & down the fields before the seeder??? :) :) :) :) Around here the drifts are about 2-3 feet deep most Februarys....
Just having a little fun. :) It's neat to see the different timing & challenges in different regions. :)
--->Paul
tim[in]
09-18-2004 18:06:29
 Re: Spring vs Fall Alfalfa in reply to paul, 09-18-2004 10:44:37
nope . we use a sleigh ,unless it's wet then we use a jon boat. have a hell of a time trying to keep the swaths even tho ,trying to see out that little moon shaped window! lol
TGIN
09-18-2004 04:51:01
I like spring seeding best , usually get a better stand and you`ll have a better chance of getting the rain you need . I`m old school , I like to plow a new hay field and make a good seedbed . Fert. to soil test and seed about 1.5 Bu. oats for cover crop , my cows love that oats hay . Cut when the seed is in the milk stage .
name won't work
09-17-2004 18:07:12
Planted some this spring on bean stubble, it did excellent. Got 3 cuttings, first two were weedy third was not a weed in it. Disced it lightly and planted with a Brillion seeder. Most years it probably wouldn"t have worked, but this year was an exception. Live in central Missouri.
Larry S.
09-17-2004 10:11:24
I too have had my best seedings done in the fall. Here in north west Michigan the cut off date is August 15th. This year I put in a 10 acre field on the 20th. It has been a little dry, but I did get an excellent catch and the small showers received since has made the field look really good.
kyhayman
09-17-2004 10:05:47
The main consideration here on spring v. fall alfalfa is disease pressure. Fall planted alfalfa is susceptable to sclerotinia (no resistence and no treatment). Stand germinates and then disappears. Spring planted is susceptable to aphanomycees but there is resistence to it.
I like a very late spring planting after wheat, rye, or triticale comes off as silage.
Oliver farmer
09-17-2004 07:44:09
I live in PA and have had better luck in the fall. Both have done well, but if the stand is fall planted the first year will yield much better. Around here it is late to plant alfalfa. It needs at least 6 weeks before frost, mine has been in since August 15. I tried planting hay with wheat once and didnt like it. The stand of hay never did well. I think the best idea is planting wheat, harvesting and then planting hay in late summer.
RickL
09-17-2004 07:24:44
Joe; I have done both with oats seeding alfalfa with or oats alone and there really is not much yield difference in my area. I have a friend who we did last fallI seeded wheat with his alfalfa and the wheat still made around 60 bushel. Then again you do get lucky somtimes. I have my drill rigged up so I seed every thing in its own box now have three boxes and have 44 coulters ahead of unit. I always seed after bean crop,not corn. It just works better for me. Don't be afraid of fall seeding alot fellows do it, but when I do it I don't seem to get the stand I like that I do in the spring. You do what works for you. Thats my main crop now I quit corn. RickL
agman
09-17-2004 09:23:52
 Re: Spring vs Fall Alfalfa in reply to RickL, 09-17-2004 07:24:44
Rick,
Why did you quit corn? Just curious as I did to because I have very light sand and the cost of inputs with the variable weather was just too much at risk. Now I"m in a bean-wheat-alfalfa rotation.
RickL
09-17-2004 17:42:45
 Re: Spring vs Fall Alfalfa in reply to agman, 09-17-2004 09:23:52
agman; Corn prices just didn't pay. I just don't have much left after costs. I can make more on the first cut hay than corn will net all season. Then I have the next cuttings also. The only reason doing beans yet is it rotates with my rye. You have to get off farm markets to make it work. Example straw farm value .75 to $1.50. My retail market is $3.50 up to $6.00 bale
RickL
09-17-2004 07:24:18
RickL
09-17-2004 07:22:10
