Vermeer Baler burned up
R. John Johnson
09-16-2004 19:08:12
Bad day today. The 605 super F caught fire and burned up. Must have been a bearing that went and caught the built up hay in the baler on fire. Pointed the tractor into the wind and tried to use the fire extinguisher, but no luck. I unhooked the 4010 and let her burn. I guess this speeds up the new baler plans. Going to look at a NH 664 tomorrow morning.
John
randy ,k
09-17-2004 11:15:29
 Re: Vermeer Baler burned up in reply to R. John Johnson, 09-16-2004 19:08:12
We've had a JD and now we got a 605 C vermeer round baler .The vermeer is alot easier to fix and maintain were as the JD was a pain to fix, The NH is a good baler too my neighbor has one and he's had no major problems in 6 years and he bales about 800 bales a year.They all make hard bales if you bale the right speed and the hays perfect hard to do all the time.
Hay Dr
09-17-2004 05:40:33
The 605F was 20+ years old and I'll bet still made a rock hard bale. Look at the NH, JD and other balers of the same years. They are in the scrap yard and didn't even make a tight bale of hay when new. Get you another Vermeer and you will have another 20+ years of service while the others brands are rusting in the junk yard.
txblu
09-17-2004 09:20:24
 Re: Vermeer Baler burned up in reply to Hay Dr, 09-17-2004 05:40:33
Awwwww wwh. Baler of choice in N. TX is a green model 535 and B4 that the 530. Has been for 25 yrs that I know of. Nuttin touches it (them). See a few Vermeers, a few NH, and my Hesston (1 ea) which has a 2 gallon spray tank on the apron....if I could get to it to use if I ever had a fire.
Mark
Hay DR
09-17-2004 15:24:19
 Re: Vermeer Baler burned up in reply to txblu, 09-17-2004 09:20:24
The first year of production of the JD535 was 1989 and 1984 for the JD530 round baler. Do the math. The 605F was from 1977-1979. JD has always been playing catch-up in hay equipment. And now the Vermeer 605M has just been released Deere is 10 years behind again.
paul
09-17-2004 17:35:04
 Re: Vermeer Baler burned up in reply to Hay DR, 09-17-2004 15:24:19
Where does the 605M fall in line? Thought Vermeer had gone to some different numbering system there for a while, glad to see the # and letter back. Is this a 'regular' model, & they still have that lighter duty model, or is it the other way around?
Red balers are most popular around here, but NH & Case dealers are real close, V dealer is 50 miles away. JD just isn't as popular - mind you there are many around - even with lots of Green tractors around.
--->Paul
txblu
09-17-2004 09:20:17
Mark
James in NC
09-17-2004 05:01:15
Vermeer used to recomend keeping a six pack of can beers on the baler. When they get hot and bounced around all day they gush out when opened, a little liquid at the right time can go along way. Sorry to here your not going to look at another Vermeer, they just introduced the new M baler and it looks good.
joe e-tx
09-17-2004 09:59:56
 Re: Vermeer Baler burned up in reply to James in NC, 09-17-2004 05:01:15
james every thing you said sounds about right,except were to keep the beer.ive gone from C-->F-->J dont know if i can pull any other color.
joe
James in NC
09-17-2004 11:33:58
 Re: Vermeer Baler burned up in reply to joe e-tx, 09-17-2004 09:59:56
In the newer balers like the J you could run 1 less bale of twine and add a 6 pack or maybe a rock box on the front of the tractor if you have one. I think you just have to get creative there. I would not keep in cooler on the tractor, then the hay might not get baled at all, Ha Ha.
The next time you go by your local dealer take a look at that new M, I think you will like what you see.
Chuck in Ks.
09-17-2004 04:48:12
OUCH
I'm sorry to hear about the baler. Hope you were able to get another baler and finish.
msb
09-16-2004 20:52:47
Guess maybe you will want to spring for a water charged extingusher on the new baler? Or maybe just carry a cheap pump up sprayer filled with water? Sorry for your loss,bob
buff_man
09-17-2004 05:12:45
 Re: Vermeer Baler burned up in reply to msb, 09-16-2004 20:52:47
Stick with a nh and you willnt have any complaints. NH is by far the best out there in my opinion.
