NH 273 Baler bearings??
Tom 8N396936
09-12-2004 05:26:07
Help- I lost the sweep on my NH273 baler. just froze up. Removed both chains and it turns freely. Makes me think that the bearings on the main drive are frozen. Got the sprocket from opposite of the chamber off but can"t figure out how to replace bearings (looks like I need to slide the shaft out a bit and get a puller on them).Has anyone a clue how to do this? There is a 1/2 inch square bolt on the drive casing towards the chamber side- is this a set screw to keep the halves together? If anyone could help I would be greatful.
thanks
tom
Steve from New Holland
09-13-2004 04:29:58
 Re: NH 273 Baler bearings?? in reply to Tom 8N396936, 09-12-2004 05:26:07
Tom, you do not have to move the shaft. My question is: "Is the shaft the only thing that does not turn"? If so, you are on the right track. A torch is the easiest method. Cut the bearings off. I'm not sure how I would remove them without burning them. Steve
Tom 8N396936
09-13-2004 06:13:55
 Re: NH 273 Baler bearings?? in reply to Steve from New Holland, 09-13-2004 04:29:58
Thanks Steve. Not even sure how I could get a torch in there to remove them so its off to the local NH dealer. I think I may need to get a service manual on this thing! I do appreciate you response.
tom
