new holland 488 haybine
need help
09-10-2004 22:33:21
my neighbor's 488 haybine gets so hot you could burn your hand on the end of the sickle drive right were the cap go's on after cutting for 5 minutes. the pulley is just warm what could be the problem?I thought the bearing might be too tight but I"am not sure .It sat for three years after it was bought without being run could the bearing have gone ?.It was serviced then parked and before we started it up we greased and oiled everything.
Steve from New Holland
09-11-2004 04:34:53
 Re: new holland 488 haybine in reply to need help, 09-10-2004 22:33:21
Basicly, heat is always caused by friction. Now the reason for the friction may vary, but I'd guess the bearing is too tight. However, maybe it is too tight because things got rusty sitting around. Steve
