Manure spreader
Roy
10-06-1999 13:55:26
Have a 36 John Deere unstyled model B. What manure spreader(s) would be appropriate for this tractor.
N. Anderson
09-03-2001 13:01:51
 Re: manure spreader in reply to Roy, 10-06-1999 13:55:26
I have a turn of the century horse drawn manure spreader I believe is a John Deere model D.Can someone advise me as where I might be able to find information about it? Thanks N.Anderson
greg homme
09-10-2000 18:18:45
truck mounted manure spreaders
B.C.
10-07-1999 11:10:19
Probably one of the wooden ground drives they had back then. Maybe the Deere forum could tell you what model. We used to use an all steel, 4 wheel ground drive Deere, but I dunno the model number anymore and think it was newer than 1936.
studly
10-07-1999 08:38:22
I would think that you will need a fairly large spreader to hold a tractor of that size. I would suggest that you take the tires off first because they may not go through the beaters very well. It should look a lot nicer once it is spread though!
