Hitch Catagories
Jim Stifle
09-04-2004 19:57:25
Could someone please explain the meaning of hitch catagories to me. I have a Ford 9N and am wondering about what type of implements I can use.
Thanks in advance
Jim
paul
09-05-2004 00:57:39
 Re: Hitch Catagories in reply to Jim Stifle, 09-04-2004 19:57:25
You have cat 1 3pt hitch.
This defines the size of the lower pins, the upper pin (slightly smaller than the lower ones), the spacing between the lower pins, and the vertical height between the lower & uper pins. The length of the arms is also specified, to preserve an accurate arc of motion & pto length from one tractor to the next.
Cat 2 is bigger in all dimentions, typically for bigger implements requiring more hp.
Cat 3 is again bigger in most dimentions for implements that are heavier or take more hp. There is a very common cat 3 narrow, which shares the same width between pins of cat 2 implements. This makes it easy to use cat 2 or 3 implements on the same 100-150 hp tractor....
Cat 4 is bigger yet, for bigger loads, and also has a narrow version. These cat 4 are kinda rare, really big stuff.
Cat 0 was invented for real small garden tractors, and rarely do the tractor makers follow an apporved standard in this class. Things are all different sizes. It is also becoming common for the super sub compact new tractors to come out with cat 1 hitch size, but the arms are only cat 0 in length. Makes for ill-fitting implements....
--->Paul
Joe (Wa)
09-04-2004 21:33:27
YT hitch article.
JMS/MN
09-04-2004 21:18:21
All category dimensions are at www.asae.org.
TimFL
09-04-2004 20:15:54
It defines the size of the pins. I don,t remember exact diameters off the top of my head. Cat 0 is the smallest, about a half inch, used on very small tractors like lawn mowers. Cat I is about 3/4 or 7/8, probably what your 9-n has. CatII is about an 1 1/8 inch. Cat III is common on larger 200 hp tractors. Cat IV larger than that. Usually you can find the pins to adapt to your tractor. The other thing to note is the top link pin is usually smaller than the bottom link pins.
